Ready2gonow's avatar
Ready2gonow
2, 6 volts or 2, 12 volts
I have 2, 4 year old 12 volt marine batteries in my 5th wheel. I use no inverter, and have the factory Intelli- charger converter charger. I believe 9920 series. I usually am hooked to shore power, have a 2k generator, no solar. I plan on more boondocking this summer. I checked voltage this am at 12.8v. Unplugged from power, left a few led light s and frig on propane for 6 hrs. Rechecked voltage and it was 12.4, and slides and lights were working fine. Rehooked to 50 amp power and batteries read 13.7 v
Are my batteries still sufficient? If not, will 2, 6 volts be more efficient than my 2 12 volts of about 200 amphrs? Guys at Interstate battery told me 6 volts are longer to charge. Is that correct? Will my charge wizard fully charge 6 volt batteries? I have read on this forum that a higher voltage is needed to fully charge 6 volts. Most advice is appreciated.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
