TravelinDog's avatar
TravelinDog
Explorer II
Jul 22, 2022
2 a/c units on 1 gen?
This is a hypothetical question, for now.
Has anyone tried to run 2 a/c units with 1 large gen? 15k and 13.5k btu.
I have a 3500 watt gen with 4600 watt surge. I'm wondering if it would be possible to run both a/c units using the 30 amp twist-lock outlet if both a/c units had a soft-start installed?
  • I run my two on an Onan 5500w. I'm guessing you could run either of yours but not both.
  • Coleman lists their 13.5K Mach 3+ as drawing 12.8 amps (1540 watts) in moderate weather, or as much as 15.4 amps (1850 watts) in "desert" conditions.
    Coleman lists their 15K Mach 15 as drawing 13.9 amps (1670 watts) in moderate weather, or as much as 16.0 amps (1920 watts) in "desert" conditions.
    That's the continuous running wattage - not the startup surge.
  • Doubtful.
    Softstart only helps on startup surge, doesn't help on overall running wattage and that goes up as the temps increase..
    Try running both on your gen as is, start one up wait a few seconds then start the second one.. Then see how long it is until your breaker trips.
  • Stagger the start up and yes. From Micro air site the watts run around 1500 with the soft start in place.
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Oct 09, 2025
