EK's avatar
EK
2 Camper Batteries 12V or 6V
Ok I have heard this so many times and now I figured I would get more opinions!
I was told by 3 different RV stores/ Shops that putting 2- 6Volt batteries in Series will give me more Amp Hours than 2- 12Volt batteries in Parallel.
They tried explaining to me that if you put them in series the voltage and a.h. will go up and I said I don't think that is how it works for 6volt batteries in Series. When something is in series you get double the Volts but the amp hours stay the same.. I have a good understanding of electronics and how it works.
What is your thoughts and experience about this? Do you have 2 12v or 6v batteries? Is this different because of the deep cycle batteries? I want to get more run time out of my deep cycle batteries.
  • Amphours are amphours whether they are from a 6 volt jar or 12 volt. Wired in series battery voltage is added together and amperage remains same, and with paralleled batteries voltage is constant and amperage is summed up.
    Most 6 volt GC batteries are roughly 210 to 225 amphours, and most 12 volt batteries range from about 85 to 115 amphours depending on group size. Under most circumstances, a pair of 12 volt batteries will have very similar amount of amphours as a pair of 6 volt batteries.
    The difference lies in their construction and design. I've had both 6 and 12 volt set-ups and found that our pair of 6 volt GC batteries are proving to be more resilient when deeply discharged and are better capable of taking the abuse of camping off the grid.
    Our current set of 6 volt GC2 Interstate batteries purchased from Samsclub are still providing good, reliable service going on 5 years. I had good success with our 12 volt setup albeit with shortened longevity. With either choice how they are charged and maintained makes all the difference.
  • The two Interstate 12 volt deep cycle batteries that came with our motorhome lasted less than four years. I replaced them with two Trojan T-105 6 volt deep cycle batteries in June 2007. These batteries are still going strong after eight years. I don't worry about failure of one 6 volt battery, as deep cycle golf cart batteries are widely available.
    I don't know the difference in amp-hours, but the Trojans definitely can run the furnace much longer without getting to 50% discharge compared to past experience with the 12 volt Interstate batteries.
    The Trojans are larger (taller) than my old 12 volt batteries and are heavier. I figure that more lead in a battery means more amp-hours.
  • I use two 6-volt GC batteries, because they are true deep cycle & are better suited to the duty cycles they are subjected to. I also carry a single 12-volt, as back-up.
    I dry camp 100% of the time.
  • dockmasterdave wrote:
    I am wondering some of the same things. 1 thought that comes to my mind is, if I have 2 6v batteries and 1 goes bad, I have nothing.
    If I have 2 12v batteries and 1 goes bad, I have less amp hours, but my rig will still operate.
    Not much help to you I guess. I'll be watching the replies.
    You are right I forgot about that part if one fails you are dead in the water! I did get 2-6V batteries because I figured they are the same batteries in my UPS units so they will not go to waist no matter what. GREAT POINT!
  • I am wondering some of the same things. 1 thought that comes to my mind is, if I have 2 6v batteries and 1 goes bad, I have nothing.
