deshemar's avatar
deshemar
2 generators simultaneously for backup power
Here is a question i thought some of you might have a thought toward. I am planning on getting the champion inverter gennie for some general use. However I was thinking about some backup power for my home. Here is my thought. (i do realize that i need to do the following in a safe manner that uses a manual transfer switch to protect the power linesmen)
In order to have enough wattage to power some of my home items i would also purchase a second non-nverter gennie and use it to power one leg of a 220 breaker, and the inverter gennie to power the other leg of a 220, both wired to neutral and ground.
(Not using the parallel type set-up)
The real question is would this cause any issue.
- from using inverter/non-inverter?
- would two different gennies providing power be a problem for well pump or electric water heater?
- would there be too much "distortion" in the power supply to be useful?
Other thoughts?
thanks!
