VintageRacer
Mar 09, 2015Explorer
You won't be able to power any 240 vac loads, presumably your pump, water heater, etc. Resistive loads like the water heater just won't work right, but a motor could be quite damaged, as could the generator. They require that the two legs of the input be 100% synchronized. You could power some 120 volt loads off one leg from one generator and some off the other leg and generator, but you couldn't really do it safely. It's against code for anything inside of a panel to be powered from two independent sources, for one thing.
Brian
Brian
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 24, 2026
