BFL13
Sep 27, 2020Explorer II
dougrainer wrote:BFL13 wrote:
OP is missing in action. :(
He said he has a two way in his 1985 but standard for 1985 is three way so we still don't know his model.
I missed the part where it can be a three-way but still not need 12v. I get that now. BTW, the 2410 in our 1991 truck camper has that two button system for lighting it, and does not have indicator lights. I did not realize that means it does not need 12v connected--interesting!
Since the OP stated 2 way, I stated NO 12 volts for the RM 100. IF you have a 3 way RM 100, then you DO need a heavy Gauge 12 volt wire Positive and Negative. Doug
Yes, but I think the point is ? that you can have a 12v mode but still no 12v controls, so you don't need 12v except for the 12v mode. Wrong?
Since you are here to ask while I can, is there a clever way to know if the 2410 is on electric ok without having to go outside and feel it? The gas mode has that reflector but you can't see it unless it is dark, which is not so useful either when you can't see if it lit or not except by going outside.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
