DutchmenSport
Sep 09, 2019Explorer
It will be much simpler to use the existing wiring. If you use 1 thermostat, you'll need to run wires from the second air-conditioner to the only thermostat. That could be a nightmare trying to run wires.
I'd leave it as is and use 2 thermostats as it's designed. FYI, my Montana High Country has a heat-pump/Air conditioner up front that shares a thermostat for both AND the furnace. The back one is the same type of thermostat, capable of all 3, but only 1 wired air conditioner, no heat pump or furnace.
I don't see any advantage to what you are thinking, except a project to utilize your time.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
