kmb1966
Sep 10, 2019Explorer
dougrainer wrote:
Are you the original owner? I ask Because we sold Newmar from 1994 til 2008, and hundreds of DSDP's. NONE--NONE came from the factory with 2 wall tstats. They came with the standard(your year) 5 button Dometic wall CCC Tstat. You then had the rear Zone 2 with the remote bedroom temp Thermister. Now, believe it or not, over those early years I saw a few Newmar's with just 1 Roof AC (DSDP Diesel and Gas model). Usually sold to dealers in the NE and NW. So, is it possible your model came with 1 AC and somebody added an extra and used a wall tstat? OR, there was a problem with the original set up and the Tech that was trying to fix installed that 2nd Bedroom wall tstat? My point being, you should have the communication wiring in place for easy change out to new Penguins and new 10 button CCC wall tstat. I will bet you also have the Bedroom Rear remote Thermister someplace in the Bedroom on the wall. Doug
100% accurate. I am not the original owner, but he is a good friend of mine. YES, it originally had 2 a/c units, but only 1 thermostat. Apparently when the rear a/c had to be replaced, the installer could not figure out how to hook up the system, so they installed a 2nd thermostat for the rear a/c, leaving the front thermostat to operate the furnace and the front a/c.
But I am not having problems with the rear a/c. First it seems to have a cycling problem of some sort. The compressor and fan come on and blow cold air, but before it reaches the set-point, the compressor will cut off and fan will stay on (if in the Fan-ON position). The temps will not be at the set-point, and after 20 minutes or so, the compressor will come back on for approx 10 minutes, then the compressor will cut back off, fan remaining on. This continues to repeat. Sometimes it reaches the set-point (at night I have it set to 70) and sometimes it does not. The rear a/c also has a squeaky blower at times waking everyone up in the middle of the night. uggg. I am trying to solve all this, and will consider replacing both units, but trying to make sure the installer truly knows what he is doing. unfortunately many don't. Yes, also I see a rear bedroom temperature thermistor. I don't know where the others are located. looking for them.
thank you for your help in advance.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
