dougrainer
Sep 10, 2019Nomad
IF the CCC wall tstat is NOT in an overhead cabinet the CCC wall tstat is Zone 1 temp sensor. You have all the wiring to do a new change out. I will bet the original replacement, the Penguin was a 10 button control board and will not work with the 5 button and that is why they installed a new tstat in the bedroom. Anybody that did this should NOT be working on RV's. If you buy 2 new Penguins, they will have the onboard control boards already and you just purchase a 10 button wall CCC tstat. ALL the wiring to connect is already there. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
