arthurw
Dec 26, 2025Explorer
Hi, on a 2000 Fleetwood Pace Arrow Vision on the F53 chassis, a solenoid-type battery isolator is typically used rather than a diode isolator. It is usually located in a front compartment or near the power distribution center, sometimes in the engine bay. If the house batteries are not charging from the alternator while the engine is running, the most common causes are a failed isolator solenoid, a missing ignition trigger signal, or a wiring or fuse issue between the chassis and house batteries.
