ewarnerusa
Feb 13, 2015Nomad
While the wiring can certainly be a culprit, I think getting hung up on it's diameter isn't all that appropriate when you are not pulling the max rated continuous load from the inverter. Granted, the 1500 volt amps or so that the OP is probably loading the inverter with is quite a bit but I think 1/0 cable should accommodate that provided that the wire length isn't too long. I think the culprit is only 2 x 12 batteries. As already pointed out in this thread, you would want 3 or more 12V batteries to deal with the big voltage drop that the 1500 VA load would put on them. I have this same issue with my 1500 watt PSW inverter and TT microwave. It can run it for about 5-10 seconds before the inverter cuts out.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
