jaycocreek
Jan 16, 2022Explorer II
Hemi Joel wrote:
Hi, what is the right inverter for my truck camper? I will use it a couple time per day in short bursts to run the microwave, and the Kurig coffee maker. Plus sometimes for longer stretches to run the heating pad or charge the computer. That's about all. I will switch it off when not in use, so it needs a remote switch (preferably hard wired) and it does not need an automatic power saver mode. It doesn't need to have a charger.
My camper has 3 group 31 lead acid battery's, 400 watts of solar, and a converter/charger.
I want proven quality that will last for years, not some unreliable piece of junk that will fizzle when I'm on the road.
Your recommendations will be much appreciated! Thanks, Joel
I looked for a long time before I took the jump on a PSW inverter..I found a Wagan MSW on closeout for $60 and couldn't pass it up with a 2-year warranty..Works flawlessly even on the microwave..Full digital microwaves humms with it but the non digital(dial) microwave works just like it was on reg power,no extra humm at all..One of the few MSW inverters that is recommended for microwaves...
I still wanted a larger PSW that I had been looking for a long time..i went with a Wagan (2 year warranty) 1000 true sine inverter...It runs the microwave at 1130 watts(victron smart shunt) fine so far..Short on cash or I would have gone larger..renogy had a 2000 watt PSW for $200...Will Prowse gives the Giandel a good review and my 300 watt Giandel has worked great...I just decided I wanted a unit that was warranted for 2 years..
Goof luck on your choice...Jayco
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
