wa8yxm
Jan 16, 2022Explorer III
I'm using a Xantrex Freedom. it's cheap but it works Connections (120 volt side) are **** however.. used to use a prosine (no longer made) much better.
Any of the ones above. most all the 2KW inverters (or larger) are well made (I would not hesitate to recommend whatever you find with the following suggestion
LOOK at how you connect
The Prosine had wire leads and wire nuts to connect the stranded cable to solid ROMEX... I'm not a fan of wire nuts and yes had one fail (They don't fail after I fix 'em)
The Freedom has this thing where you move a lever and stick a wire in a hole. the hole is 12 ga. a 2,000 watt inverter really needs 10ga.. (See the problem)
The wire leads with wire nuts are ok if you do 'em right
Wire bent around a screw is my preferred connection.
Or a proper lug and bolt (like the 12 volt connections on dang near all of 'em)
One thing to look for is a remote.. I like the wired kind not the bluetooth/wi-fi kind.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
