RLS7201
Feb 18, 2022Explorer II
Hemi Joel wrote:
OK, I bought the Xantrex and there is a problem.
The issue I am seeking help with is that I just installed the new inverter and it wont run my Keurig coffee pot, labeled 1450 watts.
This is the inverter, 1800 watt, 3000 surge. Xantrex 2000
Wired with 4 feet of 1 gauge copper to a trio of group 31 lead acid battery's that are tied together with 4 gauge cable less that 1 foot each, with the inverter connected to the center battery. There is a 250 amp fuse in the positive 1 gauge cable, 1 foot from the battery. Battery's are charged by 2 - 200 watt solar panels and an MPPT. Plus the converter when on shore power.
When the coffee maker tried to start, the inverter stopped it with an overload error code. How can that be? What is my diagnosis procedure? how can 200 A squeeze through the tiny little filament in that fuse?
Thanks for any help.
I am parked next to a gentleman with the same Keurig problem. Only he has a 3K inverter on line. Looks like the Keurig may produce some back EMF that confuses some interferers.
Richard
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
