wbilotta's avatar
wbilotta
2001 Damon Intruder hazard problem
Tried to use the hazards yesterday and nothing. When I push the column mounted switch nothing happens but when I press the brake pedal both turn signal lights on the dash light up solid, not flashing. A mechanic friend said there may be two flashers, one for the turn signals and one for the hazards but I could only locate the turn signal flasher.
Does anyone know where I could look for the hazard flasher or is the problem in the column mounted switch?
  • Your flasher can be ANYWHERE.
    My freightliner chassis, the flasher is in the rear of the coach in an electrical compartment.
  • wa8yxm wrote:
    Hazard flasher is, I believe, under dash likely hanging loose above steering column, Option 2 would be the main fuse box under the hood, dead center. But I think it's the one hanging loose.
    Turn signal flasher is over on the AUX panel near the parking brake,
    I found one flasher hanging loose but that is the turn signal flasher.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
  • There should be a flasher for the hazard lights. The owners manual should show it's location. If you do not have the owners manual, a call to the vehicle dealership should be able to answer that question as to location of the flasher. JMo
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
