kountryparson's avatar
May 22, 2015
2001 Dodge cummins 5.9
I have a 2001 Dodge cummins it has 129,000 miles on it. Runs good and I have kept it serviced. I serviced the transmission at 100,000 miles had to replace solenoid, transduce and filter. I have only driven it 29,000 miles should I change fluid and filter again. Did that back in 2010. I've heard that the transmission is the weak point of the truck. I've changed lift pump and replaced enjector pump about 1,000 miles ago. I'm thinking about traveling out west this summer. I pull a 2010 28ft. Coachmen Express some 5500 pounds.
Anything you think I should check.
