JaxDad
Oct 09, 2018Explorer III
BFL13 wrote:
I have a wire thing I made up using two cig plugs one at each end. When on shore power for a long time, I stick one in the dash cig lighter socket and the other in the 12v socket that came with the television antenna panel overhead, which is on house battery.
I went a little further to prevent over-charging the chassis battery.
I put a regular 6 amp automatic battery charger in the compartment with the A/V equipment hard-wired to the chassis battery. The charger is plugged into an old school mechanical lamp timer set to come on for only 2 hours a day.
Whenever it's connected to shore power the chassis gets an up to 6 amp charge for a couple of hours a day.
If it's parked for long in the winter I correct the time of day on the timer so that the charge cycle occurs in the wee hours of the morning when the temps are the coldest.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
