TWZMYJP
Nov 03, 2015Explorer
Well, found the issue but not the source/location of the problem... I pulled the lense off the passenger side cab light fixture and verified the bulb was good. Out of curiosity, I pulled the bulb to expose the conductors in the fixture and put a test light on the conductors. To my amazement, the first conductor I touched had power to it?! Sadly though, so did the other conductor... I'm no electrician but I think this means I've lost ground somewhere... So I pulled a lense off a fixture down on the belt line that was working to verify wire colors for power and ground, and then ran a jumper from battery ground to the supposed ground wire on the cab light fixture. Sure enough, all of the cab clearance lights popped on!!
So... I made a quasi permanent jumper and tied it to a ground location inside the coach behind the cabinets. Not sure where or how the real ground failed, but the lights are working again now.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
