DrewE
Nov 04, 2015Explorer III
TWZMYJP wrote:
No, actually one of the side markers at the belt line was also dead, and turned out to have the same issue with +12v on both conductors... That is where I was able to find the wiring behind the kitchen cabinets and tap into the ground and run a new ground leg, which makes all of the lights work again. There must be either a separate ground circuit for those particular lights, or a break in the ground wire somewhere between them and the remaining clearance lights, as all of the others worked just fine??
Sounds like it. Were I in your shoes, I'd call the repair good enough and cease worrying about it and go camping instead.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
