Corkey05
Jan 11, 2018Explorer
centerline wrote:
a whine in a diesel engine is usually 1 of 2 things... turbo bearings, or a leak in the air charge system.
when the air charge system pressurizes, a pinhole in a humphose, or a loose clamp can make an irritating whine....
both the turbo and a leak in the air charge side will make a whine when the turbo starts working... but the best way to tell if you have a turbo issue is to pull the intake hose (air cleaner side) off of it and wiggle the shaft... if it has any side to side play, the bearings are on their way out... but a little end play can be normal.
if the turbo checks out good, then you will will have to check all the rubber hoses in the charge side of the turbo....
if you can get it to whine while running in the driveway, use a 3-6ft length of hose and hold one end to your ear and use the other end to listen to the various hoses, or other suspect items, until you pinpoint the source of the noise.
X2
Mine was a clamp, after the CAC had been removed and reinstalled. A clamp at the CAC just needed to be slightly shifted and tightened - then all was good. You have nothing to lose by checking every clamp between the turbo and the CAC. If one looks a little "off", reposition it so it's straight.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
