lbond01
Jan 11, 2018Explorer
Video was taken in driveway. It makes the same noise going down the road. Boy is it loud when you are accelerating on the onramp with a sound wall next to the road. The fan is a fixed blade with no clutch, which was replaced with factory OEM part.I will check all my boot/couples connections again. The clamps for the couplers were replaced with the upgraded design, which has a bigger spring. On the boot to the charge air cooler I had to modify the clamp (remove washer and bend stud), I will go back to the old clamp tomorrow. Thanks for all the ideas!!
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
