wasatchmtnatvr
Feb 28, 2014Explorer
Go to different parts place. Yours doesn't know Jack. Top left corner of t-stat says off. Gently slide t-stat bar to left till it stops, you will feel resistance and now firmly continue another 1/8 inch. You will feel it. Furnace should shut off 2 minutes later. You said lp tank valve shut off, you cannot have heat from lp furnace unless fuel is supplied to device. You may mistake a fully open service valve on for being closed. Try opening it, if it doesn't open you already have it open. Firmly turn clockwise to close. If it is closed you may have a leaking service valve not fully closing.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
