Rgtopda's avatar
Rgtopda
2005 fleetwod discovery
There are four slides to this motorhome and I replaced the passenger side kitchen motor with little effort. however I cannot find the rear slide motor on the passenger side. I looked under the motorhome and I am at at loss as to where I can manually open the rear slide. this slide is not the one on the bed slide ?
1 Reply
  • I am a dummy it is a excursion. it is not the slide where the bed is,,it is the wardrobe slide. I have looked at the manual you posted but it is the opposite side and does not show where the motor is located, it is gear driven. no chain or hydraulic. Sorry I left out so much info. someone stated it was down in the luggage area but did not see it....The other three slides are a piece of cake.
