jake2250
Sep 04, 2013Explorer
We have an 2006 Pioneer 18CK, Love it!! But I had to redo all of the roof sealant, I used eternabond tape, also I have spent the last three days digging out all of the putty on all of the corner/edge seals,, some I re puttied, some I used Dicore and sealed all of it!!
I believe Every trailer out there needs to have this done some time during its use!!
The putty dries and cracks,, the Dicore they use at the factory is a huge mess!! They must use at least an 1-1/2 nozzle to apply it with!!
I gotta say,, Eternabond has been wonderful!! I have only had to touch up about three areas that have worked loose,, and they were really small!!
The corner seals that run the height of the trailer were dried and cracked,, I dug then out and used Dicor sealant on them..
Again,, this has been a three day job just on maintenance!! Also,, over the last two years I have removed ALL windows and resealed!!!
I did have a small leak at the rear of the toilet and it turned out to be the water supply,, they cut it to short at the factory and the strain created a small leak.. I re cut and added a larger piece of pipe,, Hopefully high and dry now!!
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
