Johno02
Aug 15, 2018Explorer
Problem is what was called a "flat Spot" on the starter, or the starter solenoid. Have had the same problem on many cars over the years, Cure is to replace or rebuild the starter motor. Usually replace the solenoid at the same time, just to complete the job right. As far as getting it off, good luck there, someone else will have to help with that.
