TenOC's avatar
TenOC
Nomad
May 26, 2023
2005 Norcold refrigerator -- shore power not cooling
2005 Norcold refrigerator connected to shore power, temperature set number 9, mode AC, outside temperature 80°, inside temperature 70°. I cannot get the inside of the refrigerator to cool below 45° sometimes it is 50° which is unacceptable to for food storage. Trailer is level.
I have tried running on propane with no joy
Any suggestions are welcome.
  • enblethen wrote:
    Since unit doesn't work on lp and marginal on electric, test the thermistor.
    Thermistor testing
    Potentially bad circuit board. I prefer Dinosaur Electronics replacements..
    A BAD thermister will test GOOD most of the time. If my checkout shows a good refer, then he needs to replace the Thermister. Doug
  • N821 has just 1- 120 element.
    1. Verify ventilation from outside lower refer access door up thru the roof is clear of obstructions. You will have to remove the top roof vent to verify upper area. Just 4 screws removes it
    2. Verify your model does NOT have a 12 volt cooling fan just below the rear condensor coil. Step 1 with a flashlight will verify that.
    3. If 1 and 2 check out, you then disconnect the 120 heat element from the rear control board and run 120 volts direct to the Heat Element for 24 hours. IF after 24 hours the freezer is NOT below 10 degrees and the lower refer is NOT below 40 degrees, your Cooling Unit is bad and needs replaced. Doug
  • Since unit doesn't work on lp and marginal on electric, test the thermistor.
    Thermistor testing
  • dougrainer wrote:
    Installed in a slide room? Doug
    No
  • Ranger Smith wrote:
    120 volt heater went bad??
    The "tube" is hot so the heater is working. Likewise, all the fuses are good.
  • Model of your Norcold?
    Check fuses on circuit board
    Check connectors on circuit board
