Gene_Ginny
Feb 12, 2014Explorer
TammyJenkins wrote:At first glance it would seem that the 50' line may be freezing, even with insulation around the line.
.... Now the weather is freezing occassionally and there is recurring water on the floor of the bathroom. .....
TammyJenkins wrote:Trailer black tanks and grey tanks do not have a cleanout like you would find in "stick and brick" houses.
Does anyone know where the sewage cleanout would be located? ......
2006 Gulf Stream park modelDoes this park model have grey and black tanks with dump valves that have to be opened to dump or does it drain directly to the sewer line?
It does sound as if "stuff" is not flowing downhill fast enough in the freeing weather. If you do have dump valves then the tank should not be dumped untill it is at least 3/4 full as mentioned above. The larger amount of water released when you dump will wash the "stuff" down the line, otherwise it tends to stick to the pipe.
Another thought, Is the drain line smooth PVC pipe or the RV type sewer hose with all those ridges that collect "stuff"?
