Big_Katuna
Aug 31, 2018Explorer II
For the price of visiting a service center to get codes read, buy a Vmspec Silverleaf software and cable for your laptop.
This gives you real-time display of all your parameter including normal ranges and what’s over/under.
Plus when you get the code explanation you can call their tech support and they can help you diagnose the problem.
I was getting check engine intermittently and it was a tight wire pulling hard on the turbo boost sensor. Under load the engine would lean some and wire would pull the connector off enough to send a false reading.
Is your temp gauge saying it’s hot?
Mine doesn’t rise on an uphill.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
