Wire_Man
Aug 31, 2018Explorer
I just came in from learning how to use the diagnostic part of my computer type dash, when I got to stored faults it said none (this is what the local garage told me as well)
I am going to take it to a citified Cummins garage as suggested. I have washed out the radiator twice already this summer, have had both fuel filters replaced, I checked the coolant level and it is full, the temperature will rise on a pull/grade and the fan will kick on and it will start dropping. It runs around 190* and will climb to 205* then you can tell the fan kicks on because it will hold there or go up a little more then start dropping back to the 190’s
Thank you so much for all the reply’s as it helps me remember to check things a little closer.
I will reply with what the shop finds, thanks again, Barney
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
