- Home_SkilletExplorer III recently put LED tail lights on my RV.
Had to put an LED compatible flasher relay in.
Mounted on the brake pedal bracket, by the fuse box. - 2oldmanExplorer IIYou're right. I should have said "Your owner's manual may have this."
- Coyote1ExplorerThe smart remark did not help, 2oldman! I have the fuse diagram in my "Owner's Manual" but it does not show the location of the flasher relay.
Anyway, I found it by listening to where the clicking was coming from. It is below and left of the steering wheel. If you look straight back you will see a shinny tab that it is mounted to.
Thanks to those who truly try to help - 2oldmanExplorer IIDon't suppose you have an owner's manual anywhere...
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
