WYDOIN's avatar
WYDOIN
2012 Dutchman Voltage 5th Wheel (Speaker Issue)
Ok I’ll try and explain this the best I can. 2012 Dutchman Voltage 5th Wheel (Speaker Issue) The 2 small speakers above the couch I can’t get any sound out of. I got a test sound to come through them from a setting on the Main TV above the door/electrical panel. But when I play the TV no sound comes out of those speakers. Am I missing something??? All other speakers work.
  • It sounds like you must have a setting in the menu of the TV to cut/enable external speakers. I'd suggest to break out the owner's manual.
  • What do you have your amplifier set at? I use D.IN for TV and that makes sound come out of all 6 speakers.
  • I think you will have better response to your question if this were in the Tech Issues forum. I will move it there. Good luck.
    Barney
