Racorman's avatar
Racorman
2012 Ford V-10 Fuse Box Question for a Class A Itasca
We just purchased a used 2012 Itasca Sonova 30A, with a Ford V-10. Some of the manuals are missing and I’m chasing down why both my front map lights are not working. I have no idea which fuses might operate both the driver and passenger map lights. I wondered if anyone could provide me some direction as to what fuses are involved. I suspect that these lights are on the Ford chassis fuse block. Also, is there an online site to obtain a schematic and diagram to show which Ford mini fuse locations and what they control. The coach fuses are clearly marked.
Here is a photo of the fuse block under the driver side dash. Thanks
  • Ford has PDF's for most chassis available on-line.
  • I would suggest a google search for e350 or e450 owners manual, that should tell you what you need.
    Good Luck
