dougrainer
Mar 16, 2020Nomad
You need to replace the COMPLETE TPO roof. Yes, you can peel the bad section up and replace the decking that is weak. But getting old TPO to adhere back down will be almost impossible. Crossroad roof decking was NOT the normal thickness of standard deck material. The weakness was like that from new. We sold and serviced Crossroads back then. The correct way to fix is to remove the old TPO and redeck/overlay the old deck and then glue down new TPO. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
