We are at a campground. One A/C is working the other one will not turn on. It has 50amp but the campground only has 30amp. Any suggestions would be helpful. Thanks
1. Normally you can only run 1 A/C unit on a 30 amp service. If you tried to run two, then you probably tripped a breaker and this is why the other A/C will not come on. Check your breakers for a tripped circuit....
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Mar 31, 2026
