time2roll
Feb 23, 2017Nomad
gwgautney wrote:Might be normal but it is odd by current standards.
I was curious about my 12 volt lightning. If I disconnect my battery while hooked to shore power my lights will not work. Does my battery have to be hooked up to complete the cycle or do I have another issue. I was under the assumption that everything should work strictly off of shore power. Also the refrigerator light cuts off when I disconnect the battery.
Thanks
What exactly are you disconnecting off the battery terminal?
Or are you using a switch?
Does the converter or 12v fuse panel have a make and model number?
