Sam_Spade
Feb 24, 2017Explorer
1Wheeldrive wrote:
If you take the battery of of the circuit, there is no way for the 12 volt DC power to get to the lights, fridge, furnace or water pump.
SIGH.
Absolutely and totally wrong.
MOST converters are designed to provide perfectly good 12 V power with or without a battery in place. Some will not.
The OP needs to hook up to shore power and then check the voltage at the battery, with a good battery in place......to see if the converter is working at all or not. As other posts indicated, probably not, as evidenced by seeing the same voltage at the battery whether or not the shore power is connected.
