deltadriftwood
Sep 29, 2017Explorer
2014 Freedom Elite 21c 12V Issue
Just bought the rig used. House batteries were on their last legs and went dead even with the store/use switch in store one week after I bought it. I replaced them thinking it would correct the issue.
Since then the Store / Use switch will not turn the 12V on. No click, no nothing. Everything works fine if on shore or gen. I have double checked the fuses and breakers on the panel, tested the solenoid for the cutoff click and checked an inline fuse on it, checked the driver side fuses under the dash and all in the engine compartment.
I have read about a 12V reset button on several posts but cannot find any such thing on mine even though the manual says it is behind the converter. "Should you lose 12V Power on a class C gas motor home there is a 50 Amp reset button located behind the converter" Looked everywhere. I tested the Store / use switch to see if it had any power to it. I would think that it should. It does not. The converter is a WFCO WF-8955PEC.
My feeling is that the converter is not even getting power from the house batteries some how. Any ideas greatly appreciated as this is my first RV and its already broken in a week :(
