CaptainYARRR
Mar 30, 2017Explorer
2015 Dometic 15,000 AC doesn't even try to run
Hey all,
I bought a 2015 Work and Play in October of 2016. The AC worked at first with the exception of needing to seal the unit from the condensation from the roof.
Fast forward this Spring. I turned on the unit to make sure everything was working. It's just blowing. You can't hear the compressor even try to turn on.
What's the troubleshooting for this? I suspect the thermostat because of the fact you don't hear anything trying to kick on.
Everything is completely clean from top to bottom. The dealer that sealed it up said everything looks good and I shouldn't have any problems.
