ernie1
Nov 16, 2022Explorer II
2018 Sprinter has tendency to overfill on fill up
My 2018 rv built on a 2017 Mercedes Sprinter chassis will periodically spew diesel out of the fill spout because it is overfilled and the nozzle doesn't shut off. If I'm not close enough to the vehicle to grab the filler hose and shut it off, it will continue probably until the service station's tank is totally emptied. To be clear, I'm not bumping the filler lever to maximize the fill. The nozzle's lever to provide an automatic fill is in the latched position and it is supposed to unlatch when the tank has reached the proper level. I've even tried using the slower fill position on the filler nozzle but I still have the same results. Another point is that this problem has presented itself even when the vehicle was new so it's not an issue with it. There were a couple of incidents where I was monitoring the fill by keeping my hand on the filler lever and the diesel came pouring out anyway.
What I have also noticed is the problem happens more frequently in rural areas where I think the local agencies that are monitoring these stations are not doing their jobs and allowing them to use faulty equipment.
My purpose for this posting is to ask if others that have a similar vehicle if they are or have experienced this problem.
