Hondo99
Aug 19, 2023Explorer
Grit dog wrote:
I realize comprehension is low sometimes on this forum, as I’m the only one who apparently picked up on you saying your AC blowing 70deg air out of it.
So you’re trading in a trailer with a bad air conditioner for one with basically the same unless you go 50A dual AC but with a working AC?
Even if you don’t want to diagnose why your AC is putting out room temp air, if you can use basic hand tools and reconnect 3 wire nuts back to the same wires, you can fix your problem in about an hour just by buying a new AC.
And you can weather proof the stuff a bit for a bit more efficiency just like you’d want to with any RV. Especially if you’re trying to live in a gray sardine can in some of the hottest weather in the country.
This be like the guy who’s gonna spend $2700 for 70ah more battery capacity….why?
30 foot I know the insulation is little, the walls are hot ??
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
