CalkiddExplorerAug 31, 2015220 Volt mishapI went to plug in my RV inside my parents shop my dad had wired. The outlet is a 220 volts with three prongs. Something similar you would plug in a welder or compressor. I used the 30 amp RV receptac...Show More
sch911ExplorerAug 31, 2015I think you burned out the 120V AC heating element. If it works on Gas the board is most likely good.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related Content12 volt only refrigerator12 Volt Power Issue220 volt capable PSW inverter30 amp 110 or 220 volt?No 12 Volt without converter
