CalkiddExplorerAug 31, 2015220 Volt mishapI went to plug in my RV inside my parents shop my dad had wired. The outlet is a 220 volts with three prongs. Something similar you would plug in a welder or compressor. I used the 30 amp RV receptac...Show More
Old-BiscuitExplorer IIIAug 31, 2015Continue what you are doing and nextr post will be about more than a fried fridge element.YOU are not an electician. YOU do not understand 50A , 30A wiringYOU do not belong messing around with itHARSH words....you bet.BUT you are messing outside your 'sand box; and need to stop before you burn down the house or get injured.Then my words won't seem so harsh.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related Content12 volt only refrigerator12 Volt Power Issue220 volt capable PSW inverter30 amp 110 or 220 volt?No 12 Volt without converter
