CalkiddExplorerAug 31, 2015220 Volt mishapI went to plug in my RV inside my parents shop my dad had wired. The outlet is a 220 volts with three prongs. Something similar you would plug in a welder or compressor. I used the 30 amp RV receptac...Show More
mkirschNomad IISep 01, 2015You're NOT going to be able to adapt this from a standard 3-prong welding outlet. Not even temporarily. Especially as pictured.It would not be too much expense to get an electrician in to install a proper 50A circuit and plug for your camper.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related Content12 volt only refrigerator12 Volt Power Issue220 volt capable PSW inverter30 amp 110 or 220 volt?No 12 Volt without converter
