Calkidd
Aug 31, 2015Explorer
220 Volt mishap
I went to plug in my RV inside my parents shop my dad had wired. The outlet is a 220 volts with three prongs. Something similar you would plug in a welder or compressor. I used the 30 amp RV receptac...
Calkidd wrote:
What I have done, and it is working, is I kept the 50 amp 240 household service receptacal wired as is. I have an 10 ga 3 wired extension cord with the one end having the 3 prong female 50 amp plug. I wired in a 50 amp RV plug with the black and white wired to the two hot legs and dropped the neutral. I kept the ground the same. The common is not necessarily needed since this is AC power.
