CalkiddExplorerAug 31, 2015220 Volt mishapI went to plug in my RV inside my parents shop my dad had wired. The outlet is a 220 volts with three prongs. Something similar you would plug in a welder or compressor. I used the 30 amp RV receptac...Show More
Old-BiscuitExplorer IIISep 01, 2015:S :S :S :S :S :S :SI should have not posted how to wire up the 30A RV and just left my original post.YOU are not an electricianYOU do not understand 50A , 30A wiringYOU do not belong messing around with itHARSH words....you bet.BUT you are messing outside your 'sand box; and need to stop before you burn down the house or get injured.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related Content12 volt only refrigerator12 Volt Power Issue220 volt capable PSW inverter30 amp 110 or 220 volt?No 12 Volt without converter
