mlts22's avatar
mlts22
Explorer II
Oct 06, 2015
24 volt battery bank?
Other than needing to use a DC-DC converter for the 12 volt system, what problems would there be in going with a 24 volt battery bank for a custom rig?
The reason for this is that Magnum Energy has a PSW hybrid inverter which can run up to 4000 watts, as well as take two 120VAC power sources at the same time (genset and shore power.) However, for this functionality, it requires 24 volts in the battery system.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 04, 2025
