mlts22's avatar
mlts22
Explorer II
Oct 05, 2015
24 volt battery bank?
Other than needing to use a DC-DC converter for the 12 volt system, what problems would there be in going with a 24 volt battery bank for a custom rig?
The reason for this is that Magnum Energy has a PSW hybrid inverter which can run up to 4000 watts, as well as take two 120VAC power sources at the same time (genset and shore power.) However, for this functionality, it requires 24 volts in the battery system.
  • Probably best to ignore the sarcasm above. 24 is fine, as long as you use a 24-12 converter of sufficient amperage. I use a 25a victron.
  • Other than a multitude of systems in your RV designed for 12VDC ( like LPG and CO detectors, furnace thermostats, refrigerator control boards, AC control boards, power chairs, electric awnings and motorized window shades, water pump, hot water heater DC control board, slide motors, etc. etc. etc. ) I can't think of a reason not to go with 24VDC battery system.
  • DrewE's avatar
    DrewE
    Explorer III
    I can't think of any particular problems. 24V wiring is in the same sort of regulatory class as 12V wiring if my memory serves me. ATC fuses and many automotive wiring connectors or contacts and similar items are frequently rated for 24V (or higher), so finding such parts should not be a big difficulty.
    At least for lights, and probably for many other devices, you should be able to find 24V equivalents which would reduce the size required for the (rather substantial) DC-DC converter. One advantage of using 24V for as many of the loads as practical is that you reduce the power loss due to voltage drop by a factor of four, all other things being equal.
  • No problems, nada ...my parents have 24 volts in their freight liner, it was sold to them with a solar rig ...
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
