CVD's avatar
CVD
24 Volt CPAP
I just picked up a new 24V CPAP machine (ResMed AirSense 10). This replaced a 20 yr old machine that I ran off AC at home and 12V DC in the RV (used the 12v TV outlet in the bedroom). Two questions:
1) Short of buying the $85- DC converter from the manufacturer (link below), is there an easy/inexpensive way to get 24V to this machine from a 12V outlet?
http://www.cpap.com/productpage/resmed-dc-converter-airsense-aircurve-10-machines.html
2) I have a cheap 400w inverter ($50 from Costco) that I use to charge misc devices. It certainly isn’t “pure sine wave”. Is a CPAP machine something that will be harmed by a non pure wave pattern? I used to think not, but this new CPAP machine is web enabled, transmitting info to my doctor. Much more sophisticated than my prior machine.
  • Looks like you will need 90W and there are DC DC boost converters that include a volt and amp meters. They are available through Amazon.
    I use the converters for other purposes and carry two (I had one fail).
  • My wife's CPAP machine worked fine on a cheap MSW unit, as will most noninductive loads. It will use more power than PSW, the wall wart ran noticeably warmer before I wired in a larger PSW unit for general usage and that is consistent with my laptop when I used to bring it.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 19, 2025
