DrewE
Aug 10, 2015Explorer III
You can't have the batteries connected in series and parallel simultaneously. Laws of physics/topology and all that.
Some cleverness in switching could allow them to be either 12V or 24V; but in 24V mode you would not be able to power 12V stuff or charge them from a 12V alternator, and in 12V mode you couldn't run the inverter. This would require some rather hefty switches or relays, and you'd still need some additional 12V battery for the other 12V systems in the RV. Mex is absolutely right; there's no real easy and inexpensive solution.
If the batteries are in good condition etc., I would suggest keeping them and exchanging the inverter with a 12V inverter.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
