PNW_Steve
May 16, 2019Explorer
RoyB wrote:2oldman wrote:RoyB wrote:Inverter, when you do a lot of high-amp draws.
I can't think of a good reason to have anything that works on 24V DC haha.
That would reduce battery current for sure... Don't know if that would off-set the cost for a 24VDC system or not... Obviously I am not into SOLAR YET hehe...
Roy Ken
Roy,
A 24 volt house battery system is not any more expensive than 12 volt for systems of comparable capacity.
I am running 4 - L16 batteries wired in series for a 24v 400a/h bank. If I had elected to go 12v and maintain the same capacity I would need the same 4 - L-16's but they would be wired as 2 parallel strings of 2 in series (2S2P) for a 12v 800a/h bank.
The cost of wiring will be less on the 24v system as you can use smaller wire.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
